Hola Estimados!!!
Tengo mi Philco PLD32HS9B, con el mismo problema de que aunque enciende el Stand by, (rojo) pero no activa el Led verde, con el Remote Control.
Necesitaría el diagrama de la monoplaca del Philco mod PLD32HS9B ,especialmente fuente principal, ya que tengo que repararla, y quiero rastrear tensiones para localizar la falla. Ya comprobé +12,2 Vcc y +33,4 Vcc en zona COLD.Pero quiero seguir buscando. M. Gracias por adelantado.
Hello dears!!!
I have my Philco PLD32HS9B, with the same problem that although it turns on the Stand by, (red) but it does not activate the green LED, with the Remote Control.
I would need the diagram of the Philco mod PLD32HS9B single board, especially a main source, since I have to repair it, and I want to trace voltages to locate the fault. I already checked +12.2 Vdc and +33.4 Vdc in the COLD zone. But I want to continue searching. Thank you very much in advance.
