Philips: 49PFG5102 - reemplazo de main
sergiol
Mensaje por sergiol »
Les hago una consulta, necesito reemplazar la placa main 715g8251-m01-b00-004t pero me ofrecen una placa con la misma referencia pero sacado de un TV Philips modelo 32PHG5102 de 32 pulgadas.
¿Es necesario cambiar el firmware o algo más para que se adapte al panel de 49 pulgadas?
Gracias de antemano por su ayuda.
Re: Philips: 49PFG5102 - reemplazo de main
Esta placa se usa en 32", 43" y 49". Si tenes el manual de servicio explica como se configura para los distintos paneles entre otras cosas:
Panel Code:
Press the following key sequence on a standard RC transmitter: “062598” directly followed by MENU and “xxx”, where “xxx” is a 3 digit decimal value
of the panel type: see column “Display Code” in below tab. After resetting the Display Code, restart the set immediately.
CTN_ALT BOM# Panel Type Display Code:
32PHG5102/77 TPT315B5-1A058.L S24C 214
32PHG5102/77 TPT315B5-1A058.L S28A 218
32PHG5102/77 TPT315B5-AN10.S SH02L 232
32PHG5102/77 TPT315B5-WX226.K S4850Y 225
32PHG5102/77 TPT320B5-AT011H S011D 235
32PHG5102/77 TPT315B5-AN10. S SH02B 229
32PHG5102/77 TPT315B5-WHBN85.K SD850A 230
32PHG5102/77 TPT315B5-WHBN85.K SDN30A 231
32PHG5102/78 TPT315B5-1A058.L S24C 214
32PHG5102/78 TPT315B5-1A058.L S28A 218
32PHG5102/78 TPT315B5-AN10.S SH02L 232
32PHG5102/78 TPT315B5-WX226.K S4850Y 225
32PHG5102/78 TPT320B5-AT011H S011D 235
32PHG5102/78 TPT315B5-AN10. S SH02B 229
32PHG5102/78 TPT315B5-WHBN85.K SD850A 230
32PHG5102/78 TPT315B5-WHBN85.K SDN30A 231
32PHD5102/55 TPT315B5-1A058.L S24C 214
32PHD5102/55 TPT320B5-AT011H S011D 235
43PFG5102/77 TPT430H3-DUYSHA.G S1BC 215
43PFG5102/77 TPT430H3-HVN01.U S082D 217
43PFG5102/77 TPT430H3-HVN01.U S082K 236
43PFG5102/77 TPT430H3-HVN01.U S272W 226
43PFG5102/78 TPT430H3-DUYSHA.G S1BC 215
43PFG5102/78 TPT430H3-HVN01.U S082D 217
43PFG5102/78 TPT430H3-HVN01.U S082K 236
43PFG5102/78 TPT430H3-HVN01.U S272W 226
43PFD5102/55 TPT430H3-HVN01.U S082D 217
49PFG5102/77 TPT490F2-FHBN0.K S8940R 216
49PFG5102/78 TPT490F2-FHBN0.K S8940R 216
49PFD5102/55 TPT490F2-FHBN0.K S8940R 216
sergiol
Genial ,lo tendre en cuenta. Muchas gracias. Saludos
Link --> PHILIPS 49PFG5102/77 <-- Link
