TPM22.5L LA
TPM22.5L LA
Chasis: TPM22.5L LA
IC Principal: MEDIATEK MT9675
MainBoard:
715GB868
715GC107
Modelos:
ArgentinaUruguayBrasil
32PHD6917/7732PHD6937/5532PHG6917/78
32PHD6927/7732PHD6947/5543PFG6917/78
43PFD6917/7743PFD6937/5550PUG7907/78
43PFD6927/7743PFD6947/55
43PUD7407/7743PUD7427/55
43PUD7437/55
ChilePerúColombia
32PHD6917/4332PHD6917/4432PHT6917/57
43PFD6917/4343PFD6917/4443PFT6917/57
715GB868.pdf
715GC107.pdf
Manual_Service_TPM22.5L_LA.pdf
[Menu Service / Modo Servicio / Modo Fábrica] TPM22.5L LA
[RESET / Restaurar a Valores de Fábrica] TPM22.5L LA
[Firmware / Archivo PKG] TPM22.5L LA: Instalación Forzada!!
Upgrade_PKG_V056.zip
[Configurar mainboard / Panel ID] TPM22.5L LA
[Sistema de Diagnóstico / Códigos de Error] TPM22.5L LA
