hola amiogos bsuco este firmware de esta hisense 43a5600
main rsag7.820.7953
panel t430hvn01
43A5600
Re: 43A5600
Boot-
EFUSE=3;
DRAM Channel A Calibration.
1T = (122 - 39) = 83 delay cells
Clock frequency = 900 MHz, Clock period = 1111 ps, 1 delay cell =13 ps
Byte 0 : Gating(-26 ~ 26), Size=53 .
Byte 1 : Gating(-26 ~ 27), Size=54 .
Byte 2 : Gating(-26 ~ 27), Size=54 .
Byte 3 : Gating(-27 ~ 27), Size=55 .
HW Byte 0 : DQS(-13 ~ 13), Size 27 , Set 0.
HW Byte 1 : DQS(-14 ~ 13), Size 28 , Set 0.
HW Byte 2 : DQS(-13 ~ 12), Size 26 , Set 0.
HW Byte 3 : DQS(-14 ~ 13), Size 28 , Set 0.
DATLAT calibration
first_step= 17 total pass= 6 best_step=19 .
TX HW Byte 0 : DQS(30 ~ 52), Size 23, Set 40.
TX HW Byte 1 : DQS(27 ~ 50), Size 24, Set 37.
TX HW Byte 2 : DQS(30 ~ 53), Size 24, Set 42.
TX HW Byte 3 : DQS(34 ~ 56), Size 23, Set 45.
DRAM A Size = 1024 Mbytes.
Start Pmain
EMMC boot
CID:0x4d7445e5
:0x5202a3cd
:0x46504433
:0x15010034
[Preloader] Boot loader from bank A.
LZHS addr:0x00100040
LZHS size:0x000defd0
LZHS size:0x00054122
LZHS checksum:0x000000ac
LZHS begin
LZHS ok
Boot
Start Lmain
MT5863 Boot Loader v0.9
MUSB_Init : ++
USB Port Using is 1, 1, 0, 0(1=using, 0=not use).
USB0: Set GPIO44 = 1.
USB1: Set GPIO45 = 1.
USB Port 0 is initial.
USB Port 1 is initial.
Set port-0 to Host mode.
Set port-1 to Host mode.
Support network!.
u4EmmcRpmbReadCounter failed. ret = 0x1
1st MAC in EEP is valid (a8:82:00:a5:e8:33)
1st : (a8:82:00:a5:e8:33)
2nd : (ff:ff:ff:ff:ff:ff)
Boot reason: A/C power on!!
[QHB] Auto Test case, always not enter QHB.
[H]Find the same Key,0xb34cfb04 ,3.
[H]IR wakeup:WriteReg[0xf002824c]=0xb649fb04.
[H]IR wakeup:WriteReg[0xf0028250]=0x7788bf00.
IR DATA register : 0x 0
T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x dad3d8, size: 21055)success!!
T8032 FW version: 6
T8032 change to loader stage...
LDR_FlashCopy 0xf010 0x5e500 0x80
[H]PowerMode=1,HotelM:addr=921,val=0,HotelPM:addr=929,val=2
Org:0x30 Flags:0x30
[H-BootCheck]Normal start and go to standby.
[H-PD]HotelMADDR:0x921,val:0.KeyLockADDR:0x922,val:1
[H-KEYPAD]Get S_Keytype val=51
[H-KEYPAD]u1KeyType:5, u1FuncType:1
[H-KEYPAD]key-list:(ListAddr)[0]-adc:401-keycode:8-topV:778-botV:661
[H-KEYPAD]key-list:(ListAddr)[1]-adc:401-keycode:10-topV:594-botV:485
[H-KEYPAD]key-list:(ListAddr)[2]-adc:401-keycode:20-topV:430-botV:315
[H-KEYPAD]key-list:(ListAddr)[3]-adc:401-keycode:40-topV:243-botV:120
[H-KEYPAD]key-list:(ListAddr)[4]-adc:401-keycode:4000-topV:72-botV:0
[H-KEYPAD]key-list:(ListAddr)[5]-adc:0-keycode:ffffffff-topV:0-botV:0
Servoadc Channel1 frist update!!!, value is 1023
Servoadc Channel1 finish update!!!, value is 1023
Disable VGA wakeup
powerdown usb port2
support WOL
wol off, MAC register switch to arm
star:mtcmos poweroff eth
_PDWNC_SetupEthernetWakeup(WOWL) _gi4PDWNCWifiWowState=0 !!
do nothing and edid will read from code
the logo brand name is his.
the logo brand is hisense,we will load on the Hisense EDID.
[H-Light]Id=27,Type=1,LeNum=204,LoNum=65535,LeRes=0,LoRes=0
[H-Light]User Light eeprom Addr=0x928,value=2
Standby
[QHB] Clear QHB flag when power down.
PDWNC_EnterPowerDown(200100,0)
SWITCH_T8032
EFUSE=3;
DATLAT calibration
Start Pmain
EMMC boot
CID:0x4d7445e5
:0x5202a3cd
:0x46504433
:0x15010034
LZHS begin
LZHS ok
Boot
Start Lmain
MUSB_Init : ++
Support network!.
T8032 FW version: 6
Org:0x30 Flags:0x30
Disable VGA wakeup
powerdown usb port2
support WOL
Standby
SWITCH_T8032
Ir a
- ↳ EMPRESAS
- ↳ ADMIRAL
- ↳ SISTEMA DE AUDIO
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 32"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 49"
- ↳ LED 50
- ↳ LED 55"
- ↳ LED 60"
- ↳ LED 65"
- ↳ REPRODUCTOR DE VIDEO
- ↳ REPRODUCTOR DVD
- ↳ REPRODUCTOR VHS/VCR
- ↳ ELECTRODOMÉSTICOS
- ↳ LAVARROPAS / SECARROPAS
- ↳ CLIMATIZACION
- ↳ AIRE ACONDICIONADO
- ↳ VENTILADORES
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ AIWA
- ↳ AUDIO HOGAR
- ↳ SUPLEMENTO
- ↳ Mecanismo CD
- ↳ NSX-200
- ↳ NSX-300
- ↳ NSX-400
- ↳ NSX-500
- ↳ NSX-800
- ↳ NSX-900
- ↳ NSX-AV
- ↳ NSX-BL
- ↳ NSX-D
- ↳ NSX-F
- ↳ NSX-S
- ↳ NSX-SZ
- ↳ NSX-T
- ↳ NSX-V
- ↳ CD PLAYERS
- ↳ CASSETTE DECK
- ↳ TOCADISCOS
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ AMERICAN AUDIO
- ↳ AUDIO PROFECIONAL
- ↳ AMPLIFICADOR / POTENCIAS
- ↳ CONSOLAS / MIXERS
- ↳ CONTROLADORAS DJ
- ↳ AOC
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ LED 22"
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 49"
- ↳ LED 50"
- ↳ MONITORES
- ↳ LCD
- ↳ LED
- ↳ ASHIMA
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ ATMA
- ↳ CLIMATIZACION
- ↳ VENTILADORES
- ↳ AUDINAC
- ↳ AUDIO HOGAR
- ↳ MINICOMPONENTES
- ↳ TOCADISCOS
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ AUO
- ↳ LCD Display
- ↳ LED Display
- ↳ LCD CELL
- ↳ AURORA
- ↳ TELEVISORES
- ↳ LED
- ↳ BEHRINGER
- ↳ BGH
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 26"
- ↳ LCD 32"
- ↳ LCD 37"
- ↳ LCD 42"
- ↳ LCD 47"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 28"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 47"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 75"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ BT14
- ↳ BT20
- ↳ BT21
- ↳ BT25
- ↳ BT29
- ↳ BT34
- ↳ CLIMATIZACION
- ↳ VENTILADORES
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ CANDY
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 32"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 75"
- ↳ CLIMATIZACION
- ↳ CHANGHONG
- ↳ HARDWARE
- ↳ CONTROL REMOTO
- ↳ CHASIS / MAINBOARD
- ↳ POWERDBOARD
- ↳ FIRMWARE
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ CROWN MUSTANG
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ CVTE
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ DAEWOO
- ↳ AUDIO HOGAR
- ↳ TELEVISORES
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 60"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ DTC25
- ↳ DTC29
- ↳ DTH14
- ↳ DTH20
- ↳ DTH21
- ↳ DTH25
- ↳ DTH29
- ↳ DTH33
- ↳ CLIMATIZACION
- ↳ VENTILADORES
- ↳ DAIHATSU
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ REPRODUCTOR DVD
- ↳ DIPLOMATIC
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ DREAN
- ↳ EMEZETA
- ↳ TELEVISORES
- ↳ LED
- ↳ ENOVA
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ MONITORES
- ↳ FISHER
- ↳ TELEVISORES
- ↳ LCD
- ↳ TRC
- ↳ GOLDSTAR
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ TRC
- ↳ GRUNDIG
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ HISENSE
- ↳ MINICOMPONENTES
- ↳ TELEVISORES
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ DRIVER LED
- ↳ DISPLAY
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 32"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 20"
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 70"
- ↳ LED 75"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ TRC 21"
- ↳ TRC 29"
- ↳ CLIMATIZACION
- ↳ HITACHI
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 26"
- ↳ LCD 32"
- ↳ LCD 37"
- ↳ LCD 42"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ CDH-14 Serie
- ↳ CDH-20 Serie
- ↳ CDH-21 Serie
- ↳ CDH-29 Serie
- ↳ CPT-14
- ↳ CPT-20
- ↳ CPT-21
- ↳ CPT-29
- ↳ CPT-34
- ↳ CLIMATIZACION
- ↳ HKC
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ HYUNDAI
- ↳ TELEVISORES
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 58"
- ↳ LED 60"
- ↳ CLIMATIZACION
- ↳ ILO
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 50"
- ↳ LED 55"
- ↳ INNOLUX
- ↳ LCD Display
- ↳ LED Display
- ↳ JBL
- ↳ AUDIO CAR
- ↳ AUTOSTEREOS
- ↳ POTENCIAS
- ↳ PARLANTES
- ↳ AUDIO HOGAR
- ↳ JVC
- ↳ AUDIO CAR
- ↳ AUTOSTEREOS
- ↳ POTENCIAS
- ↳ PARLANTES
- ↳ AUDIO HOGAR
- ↳ CD PLAYERS
- ↳ CASSETTE DECK
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 26"
- ↳ LCD 32"
- ↳ LCD 37"
- ↳ LCD 42"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 47"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ AV-14
- ↳ AV-21
- ↳ AV-T21
- ↳ AV-25
- ↳ AV-27
- ↳ AV-29
- ↳ AV-T29
- ↳ AV-31
- ↳ AV-33
- ↳ AV-35
- ↳ KANJI
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 18"
- ↳ LED 22"
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 60"
- ↳ KEN BROWN
- ↳ TELEVISORES
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ TRC
- ↳ KODAK
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ KONKA
- ↳ HARDWARE
- ↳ DriverLED
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ KTC
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ LG
- ↳ SUPLEMENTO
- ↳ REPRODUCTOR BLURAY
- ↳ REPRODUCTOR DVD
- ↳ TELEVISORES
- ↳ SUPLEMENTO
- ↳ HARDWARE
- ↳ DISPLAY
- ↳ POWERBOARD
- ↳ LGP
- ↳ PL
- ↳ PS
- ↳ LCD
- ↳ LD Series
- ↳ 22LD
- ↳ 26LD
- ↳ 32LD
- ↳ 37LD
- ↳ 42LD
- ↳ 47LD
- ↳ 55LD
- ↳ LG Series
- ↳ 22LG
- ↳ 26LG
- ↳ 32LG
- ↳ 42LG
- ↳ 47LG
- ↳ LH Serie
- ↳ 22LH
- ↳ 26LH
- ↳ 32LH
- ↳ 37LH
- ↳ 42LH
- ↳ 47LH
- ↳ 55LH
- ↳ LK Series
- ↳ 22LK
- ↳ 26LK
- ↳ 32LK
- ↳ 37LK
- ↳ 37LK
- ↳ 42LK
- ↳ 47LK
- ↳ LED
- ↳ LA Serie
- ↳ 32LA
- ↳ 39LA
- ↳ 42LA
- ↳ 47LA
- ↳ 50LA
- ↳ 55LA
- ↳ 60LA
- ↳ 65LA
- ↳ 70LA
- ↳ 84LA
- ↳ LB Serie
- ↳ 20LB
- ↳ 24LB
- ↳ 28LB
- ↳ 32LB
- ↳ 39LB
- ↳ 42LB
- ↳ 47LB
- ↳ 49LB
- ↳ 50LB
- ↳ 55LB
- ↳ 60LB
- ↳ 65LB
- ↳ 70LB
- ↳ LE Serie
- ↳ 19LE
- ↳ 22LE
- ↳ 26LE
- ↳ 32LE
- ↳ 37LE
- ↳ 42LE
- ↳ 47LE
- ↳ 55LE
- ↳ LF Serie
- ↳ 32LF
- ↳ 40LF
- ↳ 42LF
- ↳ 43LF
- ↳ 49LF
- ↳ 50LF
- ↳ 55LF
- ↳ 60LF
- ↳ 65LF
- ↳ LH Serie
- ↳ 32LH
- ↳ 43LH
- ↳ 49LH
- ↳ 55LH
- ↳ LJ Serie
- ↳ 32LJ
- ↳ 43LJ
- ↳ 49LJ
- ↳ 55LJ
- ↳ LK Series
- ↳ 32LK
- ↳ 43LK
- ↳ 49LK
- ↳ LM Serie
- ↳ 32LM
- ↳ 42LM
- ↳ 43LM
- ↳ 47LM
- ↳ 55LM
- ↳ 65LM
- ↳ 72LM
- ↳ 84LM
- ↳ LN Serie
- ↳ 32LN
- ↳ 39LN
- ↳ 42LN
- ↳ 47LN
- ↳ 50LN
- ↳ 55LN
- ↳ 60LN
- ↳ LS Serie
- ↳ 32LS
- ↳ 42LS
- ↳ 47LS
- ↳ 60LS
- ↳ LV Serie
- ↳ SUPLEMENTO
- ↳ 22LV
- ↳ 26LV
- ↳ 32LV
- ↳ 37LV
- ↳ 42LV
- ↳ 47LV
- ↳ 55LV
- ↳ LW Serie
- ↳ LX Serie
- ↳ UB Serie
- ↳ UF Serie
- ↳ 40UF
- ↳ 43UF
- ↳ 49UF
- ↳ 55UF
- ↳ 58UF
- ↳ 60UF
- ↳ 65UF
- ↳ 70UF
- ↳ 79UF
- ↳ UG Serie
- ↳ UH Serie
- ↳ 43UH
- ↳ 49UH
- ↳ 50UH
- ↳ 55UH
- ↳ 60UH
- ↳ 65UH
- ↳ 70UH
- ↳ 75UH
- ↳ 86UH
- ↳ UJ Serie
- ↳ 43UJ
- ↳ 49UJ
- ↳ 55UJ
- ↳ 60UJ
- ↳ 65UJ
- ↳ 70UJ
- ↳ 75UJ
- ↳ UK Serie
- ↳ 43UK
- ↳ 49UK
- ↳ 55UK
- ↳ 65UK
- ↳ 70UK
- ↳ 75UK
- ↳ 86UK
- ↳ UM Serie
- ↳ 43UM
- ↳ 50UM
- ↳ 55UM
- ↳ 60UM
- ↳ 65UM
- ↳ 70UM
- ↳ 75UM
- ↳ UN Serie
- ↳ 43UN
- ↳ 49UN
- ↳ 50UN
- ↳ 55UN
- ↳ 65UN
- ↳ 70UN
- ↳ 75UN
- ↳ 86UN
- ↳ UP Serie
- ↳ 43UP
- ↳ 50UP
- ↳ 55UP
- ↳ 60UP
- ↳ 65UP
- ↳ 70UP
- ↳ 75UP
- ↳ 82UP
- ↳ 86UP
- ↳ UQ Serie
- ↳ 43UQ
- ↳ 50UQ
- ↳ 55UQ
- ↳ 60UQ
- ↳ 65UQ
- ↳ 70UQ
- ↳ 75UQ
- ↳ 86UQ
- ↳ SJ Serie
- ↳ SM Serie
- ↳ 55SM
- ↳ 65SM
- ↳ 75SM
- ↳ 86SM
- ↳ OLED
- ↳ EA Serie
- ↳ EC Serie
- ↳ EG Serie
- ↳ EM Serie
- ↳ CLIMATIZACION
- ↳ COMPUTACION
- ↳ MONITORES
- ↳ LCD
- ↳ LED
- ↳ MASTER-G
- ↳ TELEVISORES
- ↳ LED
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 58"
- ↳ LED 60"
- ↳ LED 65"
- ↳ LED 70"
- ↳ LED 75"
- ↳ MEGMEET
- ↳ HARDWARE
- ↳ POWERBOARD
- ↳ MIDAS
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ MOTOROLA
- ↳ TELEVISORES
- ↳ LED
- ↳ NEX
- ↳ TELEVISORES
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ NISATO
- ↳ SUPLEMENTO
- ↳ REPRODUCTOR DVD
- ↳ TELEVISORES
- ↳ TRC
- ↳ NOBLEX
- ↳ AUDIO CAR
- ↳ AUTOSTEREOS
- ↳ PARLANTES
- ↳ AUDIO HOGAR
- ↳ SUPLEMENTO
- ↳ REPRODUCTOR DVD
- ↳ REPRODUCTOR MULTIMEDIA
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 22"
- ↳ LCD 24"
- ↳ LCD 32"
- ↳ LCD 37
- ↳ LCD 42"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 58"
- ↳ LED 65"
- ↳ LED 75"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ 14TC
- ↳ 20TC
- ↳ 21TC
- ↳ 25TC
- ↳ 27TC
- ↳ 29TC
- ↳ 33TC
- ↳ MICROONDAS
- ↳ CLIMATIZACION
- ↳ VENTILADORES
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ MONITORES
- ↳ OEM
- ↳ Suplemento
- ↳ MainBoard
- ↳ PowerBoard
- ↳ Control Remoto Universal
- ↳ ONN
- ↳ TELEVISORES
- ↳ LED
- ↳ ORIZON
- ↳ TELEVISORES
- ↳ LED
- ↳ OYILITY
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ PANASONIC
- ↳ AUDIO HOGAR
- ↳ SUPLEMENTO
- ↳ SC-AK
- ↳ SC-AKX
- ↳ SC-HC
- ↳ SC-MAX
- ↳ SC-PM
- ↳ SC-PMX
- ↳ SC-VK
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ TC-14
- ↳ TC-20
- ↳ TC-21
- ↳ TC-25
- ↳ TC-26
- ↳ TC-29
- ↳ TC-33
- ↳ PANAVOX
- ↳ TELEVISORES
- ↳ LED
- ↳ PANORAMIC
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ PHILCO
- ↳ AUDIO CAR
- ↳ SUPLEMENTO
- ↳ AUTOSTEREOS
- ↳ AUDIO HOGAR
- ↳ AMP Serie
- ↳ APMJ Serie
- ↳ SAP Serie
- ↳ SUPLEMENTO
- ↳ REPRODUCTOR DVD
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 27"
- ↳ LCD 32"
- ↳ LCD 42"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ PF
- ↳ PFS
- ↳ PM
- ↳ PS
- ↳ LAVAVAJILLAS
- ↳ CLIMATIZACION
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ MONITORES
- ↳ PHILIPS
- ↳ AUDIO HOGAR
- ↳ SUPLEMENTO
- ↳ CD PLAYERS
- ↳ CASSETTE DECK
- ↳ SUPLEMENTO
- ↳ REPRODUCTOR DVD
- ↳ HOME CINEMA
- ↳ TELEVISORES
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ 715G3xxx
- ↳ 715G4xxx
- ↳ 715G5xxx
- ↳ 715G6xxx
- ↳ 715G7xxx
- ↳ 715G8xxx
- ↳ 715G9xxx
- ↳ 715GAxxx
- ↳ 715GBxxx
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 19"
- ↳ LCD 20"
- ↳ LCD 22"
- ↳ LCD 24"
- ↳ LCD 26"
- ↳ LCD 32"
- ↳ LCD 37"
- ↳ LCD 40"
- ↳ LCD 42"
- ↳ LCD 46"
- ↳ LCD 47"
- ↳ LCD 52"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ PFL
- ↳ 22PFL
- ↳ 24PFL
- ↳ 32PFL
- ↳ 39PFL
- ↳ 40PFL
- ↳ 42PFL
- ↳ 46PFL
- ↳ 47PFL
- ↳ 55PFL
- ↳ PHG
- ↳ 24PHG
- ↳ 28PHG
- ↳ 32PHG
- ↳ PFG
- ↳ 32PFG
- ↳ 39PFG
- ↳ 40PFG
- ↳ 42PFG
- ↳ 43PFG
- ↳ 47PFG
- ↳ 48PFG
- ↳ 49PFG
- ↳ 50PFG
- ↳ 55PFG
- ↳ PUG
- ↳ 40PUG
- ↳ 43PUG
- ↳ 49PUG
- ↳ 50PUG
- ↳ 55PUG
- ↳ 65PUG
- ↳ 70PUG
- ↳ 75PUG
- ↳ PHD
- ↳ PFD
- ↳ 42PFD
- ↳ 43PFD
- ↳ PUD
- ↳ 43PUD
- ↳ 50PUD
- ↳ 55PUD
- ↳ 58PUD
- ↳ 65PUD
- ↳ 70PUD
- ↳ 75PUD
- ↳ TRC
- ↳ COMPUTACION
- ↳ MONITORES
- ↳ PIONEER
- ↳ AUDIO CAR
- ↳ AUTOSTEREOS
- ↳ POTENCIAS
- ↳ PARLANTES
- ↳ AUDIO HOGAR
- ↳ CD PLAYERS
- ↳ CASSETTE DECK
- ↳ TELEVISORES
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 47"
- ↳ LED 50"
- ↳ LED 55"
- ↳ REPRODUCTOR DVD
- ↳ QUANTIC
- ↳ TELEVISORES
- ↳ LED
- ↳ QUINT
- ↳ TELEVISORES
- ↳ LED 32"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ RCA
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 32"
- ↳ LCD 42"
- ↳ LCD 46"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 19"
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ RAR-14
- ↳ RAR-20
- ↳ RAR-21
- ↳ RAR-29
- ↳ REPRODUCTOR DVD
- ↳ CLIMATIZACION
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ MONITORES
- ↳ RECCO
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ SAMSUNG
- ↳ AUDIO HOGAR
- ↳ SUPLEMENTO
- ↳ MX-C
- ↳ MX-D
- ↳ MX-E
- ↳ MX-F
- ↳ MX-H
- ↳ MX-J
- ↳ TELEVISORES
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ BN44-001xxx
- ↳ BN44-002xxx
- ↳ BN44-003xxx
- ↳ BN44-004xxx
- ↳ BN44-005xxx
- ↳ BN44-006xxx
- ↳ BN44-007xxx
- ↳ BN44-008xxx
- ↳ DISPLAY
- ↳ BN07-xxxxxx
- ↳ BN95-xxxxxx
- ↳ LTA46
- ↳ LTA40
- ↳ LTA55
- ↳ T-CON
- ↳ ACCESORIOS
- ↳ FIRMWARE
- ↳ LCD
- ↳ C Series
- ↳ LN19C
- ↳ LN22C
- ↳ LN26C
- ↳ LN32C
- ↳ LN37C
- ↳ LN40C
- ↳ LN46C
- ↳ LN52C
- ↳ LN55C
- ↳ LN60C
- ↳ D Series
- ↳ SUPLEMENTO
- ↳ LN19D
- ↳ LN22D
- ↳ LN26D
- ↳ LN32D
- ↳ LN40D
- ↳ LN46D
- ↳ LED
- ↳ B Serie
- ↳ UN40B
- ↳ UN46B
- ↳ UN50B
- ↳ UN55B
- ↳ C Serie
- ↳ UN32C
- ↳ UN40C
- ↳ UN46C
- ↳ UN55C
- ↳ D Serie
- ↳ UN19D
- ↳ UN22D
- ↳ UN26D
- ↳ UN27D
- ↳ UN32D
- ↳ UN40D
- ↳ UN46D
- ↳ UN55D
- ↳ UN65D
- ↳ EH Serie
- ↳ UN26EH
- ↳ UN32EH
- ↳ UN40EH
- ↳ UN46EH
- ↳ UN50EH
- ↳ UN55EH
- ↳ UN60EH
- ↳ UN65EH
- ↳ ES Serie
- ↳ UN22ES
- ↳ UN32ES
- ↳ UN40ES
- ↳ UN46ES
- ↳ UN50ES
- ↳ UN55ES
- ↳ UN60ES
- ↳ UN65ES
- ↳ UN75ES
- ↳ F Serie
- ↳ UN19F
- ↳ UN22F
- ↳ UN28F
- ↳ UN29F
- ↳ UN32F
- ↳ UN40F
- ↳ UN46F
- ↳ UN50F
- ↳ UN55F
- ↳ UN60F
- ↳ UN65F
- ↳ FH Serie
- ↳ UN32FH
- ↳ UN39FH
- ↳ UN40FH
- ↳ UN46FH
- ↳ UN50FH
- ↳ UN55FH
- ↳ UN60FH
- ↳ UN65FH
- ↳ H Serie
- ↳ UN32H
- ↳ UN40H
- ↳ UN46H
- ↳ UN48H
- ↳ UN50H
- ↳ UN55H
- ↳ UN58H
- ↳ UN60H
- ↳ UN65H
- ↳ UN75H
- ↳ HU Serie
- ↳ UN40HU
- ↳ UN50HU
- ↳ UN55HU
- ↳ UN60HU
- ↳ UN65HU
- ↳ UN75HU
- ↳ UN85HU
- ↳ J Serie
- ↳ UN32J
- ↳ UN40J
- ↳ UN43J
- ↳ UN48J
- ↳ UN49J
- ↳ UN50J
- ↳ UN55J
- ↳ UN60J
- ↳ UN65J
- ↳ UN75J
- ↳ JH Serie
- ↳ UN32JH
- ↳ UN40JH
- ↳ UN46JH
- ↳ JS Serie
- ↳ UN48JS
- ↳ UN50JS
- ↳ UN55JS
- ↳ UN60JS
- ↳ UN65JS
- ↳ JU Serie
- ↳ UN40JU
- ↳ UN43JU
- ↳ UN48JU
- ↳ UN50JU
- ↳ UN55JU
- ↳ UN60JU
- ↳ UN65JU
- ↳ UN75JU
- ↳ K Serie
- ↳ UN24K
- ↳ UN28K
- ↳ UN32K
- ↳ UN40K
- ↳ UN43K
- ↳ UN49K
- ↳ UN55K
- ↳ KS Serie
- ↳ UN49KS
- ↳ UN55KS
- ↳ UN60KS
- ↳ UN65KS
- ↳ UN75KS
- ↳ UN78KS
- ↳ KU Serie
- ↳ UN40KU
- ↳ UN43KU
- ↳ UN49KU
- ↳ UN50KU
- ↳ UN55KU
- ↳ UN60KU
- ↳ UN65KU
- ↳ UN70KU
- ↳ MU Serie
- ↳ UN40MU
- ↳ UN43MU
- ↳ UN50MU
- ↳ UN55MU
- ↳ UN65MU
- ↳ UN75MU
- ↳ NU Serie
- ↳ UN43NU
- ↳ UN50NU
- ↳ UN55NU
- ↳ UN58NU
- ↳ UN65NU
- ↳ UN75NU
- ↳ UN82NU
- ↳ RU Serie
- ↳ UN43RU
- ↳ UN49RU
- ↳ UN50RU
- ↳ UN55RU
- ↳ UN58RU
- ↳ UN65RU
- ↳ UN75RU
- ↳ T Serie
- ↳ UN32T
- ↳ UN43T
- ↳ TU Serie
- ↳ UN43TU
- ↳ UN50TU
- ↳ UN55TU
- ↳ UN58TU
- ↳ UN65TU
- ↳ UN70TU
- ↳ UN75TU
- ↳ AU Serie
- ↳ UN43AU
- ↳ UN50AU
- ↳ UN55AU
- ↳ UN65AU
- ↳ UN70AU
- ↳ UN75AU
- ↳ UN85AU
- ↳ BU Serie
- ↳ UN43BU
- ↳ UN50BU
- ↳ UN55BU
- ↳ UN65BU
- ↳ UN70BU
- ↳ UN75BU
- ↳ UN85BU
- ↳ REPRODUCTOR DVD
- ↳ LAVAVAJILLAS
- ↳ CLIMATIZACION
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ TABLETS
- ↳ MONITORES
- ↳ SANHUA
- ↳ SHG Serie
- ↳ SHL Serie
- ↳ SHP Serie
- ↳ SANSEI
- ↳ AUDIO HOGAR
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 24"
- ↳ LCD 32"
- ↳ LCD 42"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ TRC
- ↳ TV 14"
- ↳ TV 20"
- ↳ TV 21"
- ↳ TV 27"
- ↳ TV 29"
- ↳ SANYO
- ↳ AUDIO HOGAR
- ↳ DCDA
- ↳ DCG
- ↳ DCL
- ↳ DCT
- ↳ REPRODUCTOR DVD
- ↳ Televisores
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD17
- ↳ LCD19
- ↳ LCD23
- ↳ LCD24
- ↳ LCD27
- ↳ LCD32
- ↳ LCD37
- ↳ LCD42
- ↳ LCD47
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LCE24
- ↳ LCE32
- ↳ LCE39
- ↳ LCE40
- ↳ LCE42
- ↳ LCE43
- ↳ LCE46
- ↳ LCE49
- ↳ LCE50
- ↳ LCE55
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ C14
- ↳ C20
- ↳ C21
- ↳ C29
- ↳ C33
- ↳ SERIE DORADA
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ SHARP
- ↳ AUDIO HOGAR
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 43"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 70"
- ↳ LED 75"
- ↳ TRC
- ↳ REPRODUCTOR DVD
- ↳ SKD
- ↳ HARDWARE
- ↳ MAINBOARD
- ↳ SKYWORTH
- ↳ HARDWARE
- ↳ DISPLAY
- ↳ CONTROL REMOTO
- ↳ MAINBOARD
- ↳ POWERBOARD
- ↳ DRIVER LED
- ↳ TELEVISORES
- ↳ LED
- ↳ SONY
- ↳ AUDIO CAR
- ↳ AUTOSTEREOS
- ↳ PARLANTES
- ↳ AUDIO HOGAR
- ↳ TELEVISORES
- ↳ LCD / LED
- ↳ SUPLEMENTO
- ↳ KDL
- ↳ BX
- ↳ KDL-22BX
- ↳ KDL-32BX
- ↳ KDL-40BX
- ↳ KDL-46BX
- ↳ KDL-55BX
- ↳ CX
- ↳ D
- ↳ EX
- ↳ KDL-22EX
- ↳ KDL-32EX
- ↳ KDL-40EX
- ↳ KDL-42EX
- ↳ KDL-46EX
- ↳ KDL-52EX
- ↳ KDL-55EX
- ↳ KDL-60EX
- ↳ FA
- ↳ HX
- ↳ KDL-32HX
- ↳ KDL-40HX
- ↳ KDL-46HX
- ↳ L
- ↳ M
- ↳ ML
- ↳ N
- ↳ NL
- ↳ NX
- ↳ R
- ↳ KDL-24R
- ↳ KDL-32R
- ↳ KDL-40R
- ↳ KDL-42R
- ↳ KDL-46R
- ↳ KDL-48R
- ↳ KDL-50R
- ↳ S
- ↳ SL
- ↳ V
- ↳ VL
- ↳ W
- ↳ KDL-32W
- ↳ KDL-40W
- ↳ KDL-42W
- ↳ KDL-46W
- ↳ KDL-48W
- ↳ KDL-50W
- ↳ WL
- ↳ XBR
- ↳ KDL-32XBR
- ↳ KDL-37XBR
- ↳ KDL-40XBR
- ↳ KDL-46XBR
- ↳ Z
- ↳ KLV
- ↳ XBR
- ↳ HARDWARE
- ↳ CONTROL REMOTO
- ↳ POWERBOARD
- ↳ REPRODUCTOR DVD
- ↳ STEEL HOME
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ TAKUMA
- ↳ TELEVISORES
- ↳ TALENT
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ TCL
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD23
- ↳ LCD24
- ↳ LCD26
- ↳ LCD27
- ↳ LCD32
- ↳ LCD40
- ↳ LCD42
- ↳ LCD46
- ↳ LCD55
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 23"
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 46"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 75"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ TRC14
- ↳ TRC21
- ↳ TRC25
- ↳ TRC29
- ↳ TRC34
- ↳ HARDWARE
- ↳ CONTROL REMOTO
- ↳ POWERBOARD
- ↳ PANEL / DISPLAY
- ↳ FIRMWARE
- ↳ TECHNICS
- ↳ SINTONIZADOR
- ↳ CD PLAYERS
- ↳ CASSETTE DECK
- ↳ TOCADISCOS
- ↳ TEDGE
- ↳ TELEVISORES
- ↳ LED
- ↳ TELEFUNKEN
- ↳ TELEVISORES
- ↳ LCD
- ↳ SUPLEMENTO
- ↳ LCD 26"
- ↳ LCD 32"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 28"
- ↳ LED 32"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ TK-14
- ↳ TK-20
- ↳ TK-21
- ↳ TKP-21
- ↳ TK-25
- ↳ TKP-25
- ↳ TK-29
- ↳ TKP-29
- ↳ TK-34
- ↳ TKP-34
- ↳ THS
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TONOMAC
- ↳ TELEVISORES
- ↳ LCD
- ↳ LCD 32"
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 39"
- ↳ LED 43"
- ↳ LED 49"
- ↳ LED 50"
- ↳ LED 55"
- ↳ TRC
- ↳ SUPLEMENTO
- ↳ TO-14
- ↳ TO-20
- ↳ TO-21
- ↳ TO-29
- ↳ TO-33
- ↳ TO-98
- ↳ TOP HOUSE
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ SUPLEMENTO
- ↳ LED 24"
- ↳ LED 32"
- ↳ LED 40"
- ↳ LED 42"
- ↳ LED 43"
- ↳ LED 47"
- ↳ LED 48"
- ↳ LED 49"
- ↳ LED 55"
- ↳ LED 65"
- ↳ LED 75"
- ↳ TRC
- ↳ TOSHIBA
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ VIEWSONIC
- ↳ TELEVISORES
- ↳ LCD
- ↳ LED
- ↳ TRC
- ↳ ZENITH
- ↳ TELEVISORES
- ↳ LED
- ↳ TRC
- ↳ AUDIO CAR
- ↳ AUDIO HOGAR
- ↳ ADMIRAL
- ↳ AIWA
- ↳ NOBLEX
- ↳ ADMIRAL
- ↳ TELEVISORES
- ↳ LCD
- ↳ ADMIRAL
- ↳ AOC
- ↳ AUDINAC
- ↳ BGH
- ↳ FHISHER
- ↳ GRUNDIG
- ↳ HISENSE
- ↳ HITACHI
- ↳ ILO
- ↳ JVC
- ↳ LG
- ↳ NOBLEX
- ↳ PANASONIC
- ↳ PHILCO
- ↳ PHILIPS
- ↳ RCA
- ↳ RECCO
- ↳ SAMSUNG
- ↳ SANSEI
- ↳ SANYO
- ↳ SHARP
- ↳ SONY
- ↳ TELEFUNKEN
- ↳ THS
- ↳ TONOMAC
- ↳ TOP HOUSE
- ↳ VIEWSONIC
- ↳ LED / OLED / QLED
- ↳ ADMIRAL
- ↳ AIWA
- ↳ AOC
- ↳ ASHIMA
- ↳ AUDINAC
- ↳ AURORA
- ↳ BGH
- ↳ CANDY
- ↳ CROWN MUSTANG
- ↳ DAEWOO
- ↳ DAIHATSU
- ↳ EMEZETA
- ↳ ENOVA
- ↳ GOLDSTAR
- ↳ GRUNDIG
- ↳ HISENSE
- ↳ HITACHI
- ↳ HYUNDAI
- ↳ ILO
- ↳ JVC
- ↳ KANJI
- ↳ KEN BROWN
- ↳ KODAK
- ↳ KONKA
- ↳ LG
- ↳ MASTER-G
- ↳ MIDAS
- ↳ MOTOROLA
- ↳ NEX
- ↳ NOBLEX
- ↳ OLYNPIC
- ↳ ONN
- ↳ ORIZON
- ↳ PANASONIC
- ↳ PANAVOX
- ↳ PANORAMIC
- ↳ PHILCO
- ↳ PHILIPS
- ↳ PIONEER
- ↳ QUANTIC
- ↳ QUINT
- ↳ RCA
- ↳ RECCO
- ↳ SAMSUNG
- ↳ SANSEI
- ↳ SANYO
- ↳ SERIE DORADA
- ↳ SHARP
- ↳ SKYWORTH
- ↳ SONY
- ↳ STEEL HOME
- ↳ TALENT
- ↳ TCL
- ↳ TEDGE
- ↳ TELEFUNKEN
- ↳ THS
- ↳ TONOMAC
- ↳ TOP HOUSE
- ↳ TOSHIBA
- ↳ VIEWSONIC
- ↳ ZENITH
- ↳ TRC
- ↳ NOBLEX
- ↳ REPRODUCTOR DVD
- ↳ ADMIRAL
- ↳ NOBLEX
- ↳ ADMIRAL
- ↳ NOBLEX
- ↳ ADMIRAL
- ↳ ATMA
- ↳ ADMIRAL
- ↳ CLIMATIZACION
- ↳ ADMIRAL
- ↳ ATMA
- ↳ VENTILADORES
- ↳ ADMIRAL
- ↳ ATMA
- ↳ COMPUTACION
- ↳ NOTEBOOKS
- ↳ ADMIRAL
- ↳ NOBLEX
- ↳ TABLETS
- ↳ ADMIRAL
- ↳ NOBLEX
- ↳ MONITORES
- ↳ NOBLEX
- ELECTRONICA GENERAL
- ↳ DATASHEET
- ↳ TUTORIALES
- ↳ CURSOS
- LABORATORIO ELECTRONICO
- ↳ SOFTWARES
- ↳ HERRAMIENTAS
- ↳ PROGRAMADORES
- ADMINISTRACION DE TALLER
- ↳ SOFTWARE DE GESTION
- ↳ GESTION / ADMINISTRACION
