QM15.1L-LA
QM15.1L-LA
Chasis: QM15.1L-LA
MainBoard: 715G7161
Modelos:
43PUG7100/77
49PUG6801/78
49PUG6801/77
49PUG7100/77
55PUG6801/78
55PUG6801/77
55PUG7100/77
55PUG7100/78
65PUG6801/77
65PUG7100/77
QM15.1L LA.pdf
[Menu Service / Modo Servicio / Modo Fábrica] QM15.1L-LA
[Códigos de Error] QM15.1L-LA
[Configurar mainboard] QM15.1L-LA
